Machines featuring the ProtoTRAK CNC
ProtoTRAK EMX CNC
Easy to use yet full CNC functionality
ProtoTRAK EMX CNC
  • Easy to learn and remember all the features
  • We recommend this control when most of the work for the machine is simple
  • Great for shops where different people use the machine occassionally
  • Vo Techs love this CNC for teaching conventional milling and introduction to CNC on the same machine
Programming
  • Program easily with simple selections and prompts in plain English
  • The ProtoTRAK EMX defines the tool path for you once you define the part geometry
Canned Cycles
  • Posn/ Drill
  • Bolt Hole
  • Pocket
  • Frame
  • Rotate
  • Repeat
Part Graphics
  • Press the LOOK key while programming to see programmed events with color graphics
Math Helps
  • Quickly calculate intersections, points of tangency, arc centers and more.
DRO Routines
  • View the most useful DRO features in a clear, color display
  • Press the Power Feed and Jog Buttons to let the servo motors do most of the work
  • Ball screws provide smooth, positive control while hand cranking
Easy Program Storage and Handling
• Save hundreds of typical programs on the internal flash drive
• Use the USB port to plug in a storage device or move programs between ProtoTRAKs and computers
• Use the optional USB flash drive that is configured to work with ProtoTRAK
Hardware
  • Digital Servo Amplifiers – custom designed for ProtoTRAK operation
  • D.C. Servo Motors – rated at 280 in-oz. continuous torque
  • Precision Ball Screws
  • Modular Design – simplifies service and maximizes uptime
  • 115V/60Hz
  • 10 amps
  • Feedrate Override of programmed feedrate and rapid
  • Polycarbonate Sealed Membrane Keypad to lock out contamination
  • 7.0" Color LCD with adjustable contrast
  • On board IDE flash memory storage for part programs
  • 2 USB ports for interface with a storage device
  • Rugged Industrial PC
  • Glass Scale on quill for Z-axis position readout
  • Jog button in DRO
  • Remote Stop/Go (RSG) switch
  • USB thumb drive for program storage and transfer
  • Diameter Cutter Compensation
  • Circular interpolation
  • Linear Interpolation
  • Conrad – provides automatic corner radius programming
  • Incremental and Absolute dimensioning
  • Error Messages – to identify programming mistakes
  • Fault Messages – for system self-diagnostics
  • Parts graphics display
  • Look – a single button press to view part graphics
  • Machine Tool Error Compensation
  • Backlash Compensation
  • Selectable Inch/mm measurement readout
  • Jog from 1 to 100 inches per minute
  • Continue Mill/eliminate repetitive data inputs while programming
  • Context help information
  • CAM to ProtoTRAK conversational language file conversion
  • Teach
  • Free offline programming available for download from our website
Customer Support
800-367-3165
Contact Us
310-608-4422
