TRL 1630HS-RX Toolroom Lathe
The high-speed version of the 1630RX
TRL 1630HS-RX Toolroom Lathe with the new ProtoTRAK RLX CNC
TRL 1630HS-RX Features
  • 16″ swing, 30″ between centers
  • Spindle through hole of 1.57″
  • 150-4000 rpm
  • At home in a lab or wherever smaller parts are made
Standard on all RX Series Lathes
  • ProtoTRAK RLX CNC integrated into the machine at the factory
  • Constant Surface Speed (CSS) Programming
  • Inch Per Revolution (IPR) Programming
  • Optional turret for automatic tool changes
  1440EX 1630RX 1630HS-RX 1845RX 2470RX 30120RX
ProtoTRAK CNC Model
ELX RLX RLX RLX RLX RLX
Height of Centers 7″ 8″ 8″ 9″ 12″ 16.5″
Distance Between Centers 40″ 30″ 30″ 45″ 70″ 118″
Swing over bed 14″ 16″ 16″ 18.1″ 24″ 33″
Swing Over Saddle Wings 14″ 16″ 16″ 17″ 24″ 33″
Swing Over Cross Slide 7″ 8.6″ 8.6″ 9.13″ 14.5″ 21.2″
Cross Slide Travel 8″ 8.5″ 8.5″ 10.6″ 12.5″ 20.5″
Tool Section Max. 3/4″ 3/4″ 3/4″ 1″ 1″ 1.5″
Coolant Tank Capacity 3 gal 8 gal 8 gal 13 gal 15 gal 48 gal
Oil Pump - Way Lubrication - 2 l 2 l 2 l 2 l 2 l
Headstock Lubrication - 1.5 gal 1.5 gal 1.85 gal 5.3 gal
6.3 gal w/oil cooler option
10 gal
Rapid Speeds 100 IPM on Z Axis
100 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
Bed
Width of Bed 8.1″ 12.6″ 12.6″ 13.4″ 14.57″ 19.69″
Height of Bed 10.6″ 12.6″ 12.6″ 12.4″ 15″ 34.44″
Spindle Nose D1-4 D1-6 A2-4 D1-6 D1-8 A2-11
Spindle Through Hole 1.56″ 2.12″ 1.57″ 2.36″ 4.09″ 6.30″
Spindle Taper MT#5 MT#6 MT#5 MT#6 MT#8 Non MT taper
Taper In Reduction Sleeve 3 n/a n/a MT#4 MT#5 MT#6
Spindle Dia. At Front Bearing 2.36″ 3.15″ 2.56″ 3.35″ 5.51″ 7.87″
Number of Bearings 2 2 5 2 2 2
Speeds/Speed Ranges 12 1 1 2 2 2
Spindle Speed Range RPM 60-2,400 150-2,500 150-4,000 80-850, 250-2,500 40-670, 100-1,800 20-415, 40-1,300
Spindle ID Thread (end of spindle) n/a M56 x 2MM Pitch M56 x 2MM Pitch n/a n/a M185 x 3.0
Quill Travel 5″ 5.75″ 5.75″ 6″ 8.5″ 8″
Quill Diameter 1.575″ 2.36″ 2.36″ 2.56″ 3.5″ 4.13″
Quill Taper Hole MT#3 MT#4 MT#4 MT#4 MT#5 MT#6
Spindle Motor
Horsepower 5 HP 7.5 HP 7.5 HP 10 HP 15 HP 30 HP
Machine Power Requirements
Voltage Control: 110V
Machine: 200V - 240V
200V to 240V 200V to 240V 200V to 240V 200V to 240V 480V +/- 10%
(432V to 528V)
Amps, Full Load Control: 8A
Machine: 15A
44A 44A 54A 75A 62A
Phase/Hz Control: 1/60
Machine: 3/60
3/60 3/60 3/60 3/60 3/60
Net (L x W x H), lbs. 73″ x 44″ x 57″
1,800 lbs
82″ x 45″ x 72″
2,750 lbs
82″ x 45″ x 72″
2,750 lbs
88″ x 55″ x 70″
3,285 lbs
129″ x 84″ x 79″
6,500 lbs
212.6″ x 86.61″ x 79.53″
18,920 lbs
Shipping (L x W x H), lbs. 78″ x 49″ x 67″
2,200 lbs
87″ x 45″ x 70″
3,420 lbs
87″ x 45″ x 70″
3,420 lbs
91″ x 52″ x 79″
3,800 lbs
134″ x 65″ x 79″
6,900 lbs
222.44″ x 90.55″ x 110.23″
19,270 lbs
Coolant Pump Motor HP 1/8 HP 1/8 HP 1/8 HP 1/8 HP 1/8 HP 1/4 HP
Spindle Motor Brake Magnetic Dynamic Dynamic Dynamic Dynamic Dynamic
Way Surface Hardness 400-450 HB 400-450 HB 400-450 HB 480-560 HB 480-560 HB 480-560 HB
Headstock Lubrication Splash Lube Oil Bath Grease Oil Bath Oil Bath Oil Bath
Tooling Kit 3/4″ 3/4″ 3/4″ 3/4″ or 1″ 1″ 1-1/4″
Chuck 6″, D1-4 8″, D1-6 6″, A2-4 8″, D1-6 12″, D1-8 20″, A2-11
5C Collet Closer D1-4 D1-6 A2-4 D1-6 n/a n/a
Turret Option n/a 3/4″, 8 Position
n/a
Buck<sup>®</sup> Chuck
1440 EX 6″ D1-4 1.57″
1630RX 8″ D1-6 2.36″
1630HS-RX 6″ A2-4 1.77″
1845RX 8″ D1-6 2.36″
2470RX 12″ D1-8 4.16″
30120RX 20″ A2-11 6.30″
8 Station Turret
8 Station Turret
Coolant supplied at each tool. Not available for the 1440EX or 30120RX.
1630RX 3/4″
1630HS-RX 3/4″
1845RX 3/4″ or 1″
2470RX 1″
4 Station Turret
4 Station Turret
1630RX 3/4″
1630HS-RX 3/4″
1845RX 3/4″ or 1″
2470RX 1″
Dorian® brand tooling kits make tool changes quick and easy. Repeatable to .001″. The kits include:
  • 1 quick change tool post
  • 4 each 3/4″ or 1″ square tool holders for turning, facing and boring
  • 1 boring tool holder (for the 3/4″ kit: 1″ holder; for the 1″ kit: 1.25″ holder)
1630RX 3/4″
1630HS-RX 3/4″
1845RX 3/4″ or 1″
2470RX 1″
30120RX 1-1/4″
Optional on 1630RX and 1630HS-RX lathes. Standard on all other models.
5C Collet Closer
5C Collet Closer
5C Collet Closer with extended taper mount nosepiece.
Not available for 2470RX or 30120RX.
1630RX 14″
1630HS-RX 14″
1845RX 14″
2470RX 20″
30120RX 30″
Lathe Diameter Type
1440EX 1.97″ Solid Brass Nib
1630RX 5″ Solid Brass Nib
1630HS-RX 5″ Solid Brass Nib
1845RX 3.94″ Solid Brass Nib
2470RX 6.5″ Solid Brass Nib
30120RX 0.79 - 7.87″ Roller
Steady Rest
Steady Rest
Lathe Diameter Type
1440EX .20 to 2.36″ Roller
1630RX .500 to 5.5″ Roller
1630HS-RX .500 to 5.5″ Roller
1845RX 0.4 to 7.87″ Roller
2470RX 1.5 to 8″ Roller
30120RX* 1.18 to 11.02″
10.43 to 21.65″
Roller
* The 30120RX comes with 2 sets of fingers.
Available for purchase at our service parts website: Remote Stop/Go Switch
DXF Converter - Lathes
  • Part alignment
  • Feature analysis (circle/arc radius and position)
  • Simple CAD construction/editing tools
  • DXF-output capability
Not available for the ProtoTRAK ELX.
Advanced Features - Lathes
  • Thread Repair
  • Gang Tool setup
  • Custom Thread event
  • Tap event
  • Search Edit
Switches and brackets to set for maximum travel limits. Tripping the switch will cause the servo motors to shut down. Note, limit switches are not especially recommended. The system software monitors voltage intensity and will shut down the servos if it detects excessive force.
Other Lathe Options
  • Coolant Pump — may be configured to operate as commanded by the Accessory Key on the ProtoTRAK RLX front panel. 1440EX coolant pump turned on and off by switch on apron.
  • LED Work Lamps — For RX series lathes: one tube-style lamp mounted to the underside of the chip enclosure, and one swing arm lamp mounted on top of lathe. The 1440EX has one lamp mounted in the chip enclosure.
  • Auxiliary Output Option — programmable output signal (not available on ProtoTRAK ELX)
  • Networking Option — lets you connect your ProtoTRAK to a network of other ProtoTRAKs or offline computers. (Not available for the ProtoTRAK ELX)
  • Offline Programming Option — ProtoTRAK RLX user interface for Windows PC, Program parts and simulate CNC Run, Modify files from current and former ProtoTRAK models (not available for the ProtoTRAK ELX)
  • TRAKing® Option — TRAKing of programs during program run, Go To Dimension in DRO Mode (not available for ProtoTRAK ELX)
  • Cam File Out Converter — ProtoTRAK RLX
EPA [Enhanced ProtoTRAK Assistance] | ProtoTRAK RLX | Lathe Programming
Tool Setup - Part 1 | ProtoTRAK RLX CNC | Lathe Programming
TRAKing & Chip Clear | ProtoTRAK RLX CNC | Lathe Programming
Defaults & Options [Part1] | ProtoTRAK RLX CNC | Lathe Programming
Defaults & Options [Part 2] | ProtoTRAK RLX CNC | Lathe Programming
TRAK CNC Lathe Models
1440EX Features:
  • 14″ swing, 40″ btw. centers
  • Spindle through hole of 1.56″
TRL 1630RX Features:
  • 16″ swing, 30″ btw. centers
  • Spindle through hole of 2.12″
1845RX Features:
  • 18″ swing, 45″ btw. centers
  • Spindle through hole of 2.36″
  • High & low speed ranges
2470RX Features:
  • 24″ swing, 70″ btw. centers
  • Spindle through hole of 4.09″
30120RX Features:
  • 43.5″ swing over 15.5″ gap
  • Spindle through hole of 6.30″
