TRAK VMC Specifications
TRAK VMC5 Vertical Machining Center
TRAK VMC5
TRAK VMC7 Vertical Machining Center
TRAK VMC7
TRAK VMC10 Vertical Machining Center
TRAK VMC10
Table size 27.56″ x 15.75″ 35.43″ x 19.69″ 44.09″ x 19.68″
T-slots (number x width x pitch) 3 x .709″ x 3.937″ 5 x .709″ x 3.150″ 5 x .709″ x 3.937″
Travel (X, Y, Z axis) with soft limits 20″ x 16″ x 20″ 30″ x 20″ x 20″ 40.75″ x 20″ x 20″
Spindle taper 40 Taper 40 Taper 40 Taper
Spindle speed range 50 - 8,000 RPM 50 - 8,000 RPM 50 - 8,000 RPM
Spindle nose diameter 3″ 3″ 3″
Tool clamping force (90 psi) 1,500 lbs 1,500 lbs 1,500 lbs
Tool holder type CAT 40 or BT 40 CAT 40 or BT 40 CAT 40 or BT 40
ATC tool capacity 16 16 16
Maximum tool weight (incl. holder) 15 lbs 15 lbs 15 lbs
Maximum tool diameter 3.14″ 3.14″ 3.14″
Carousel speed .8 sec from station to station .8 sec from station to station .8 sec from station to station
Tool selection system Bi-directional/shortest path Bi-directional/shortest path Bi-directional/shortest path
Spindle motor HP - peak 15 HP 15 HP 15 HP
Spindle motor HP - continuous 10 HP 10 HP 10 HP
Power requirements - standard 208V (200-240V is acceptable), 3P, 67.3A 208V (200-240V is acceptable), 3P, 67.3A 208V (200-240V is acceptable), 3P, 67.3A
Power requirements - optional 480V with transformer option (432-528V is acceptable), 3P, 36A 480V with transformer option (432-528V is acceptable), 3P, 36A 480V with transformer option (432-528V is acceptable), 3P, 36A
Maximum weight of workpiece 1,000 lbs 1,000 lbs 1,000 lbs
Height of table from bottom of bed*** 38″ 38″ 38″
Min. spindle nose to table distance **** 3.5″ 3.5″ 3.5″
Max. spindle nose to table distance **** 23.50″ 23.50″ 23.50″
Distance of tool carousel to table 18″ 17.50″ 17.50″
Spindle center to spindle head casting face 16.50″ 18.25″ 19.25″
Min. machine height *** 90″ 90″ 90″
Max. machine height (head all the way up) *** 106.50″ 106.50″ 106.50″
Footprint of machine with coolant tank in place 84″ x 129″ 97″ x 134″ 111″ x 134″
Weight net / shipping lbs. 7,260 / 7,610 8,360 / 8,710 9,900 / 10,250
Rapid traverse X, Y, Z 400 IPM in Toolroom Ops, 1,000 IPM in Production Ops 400 IPM in Toolroom Ops, 1,000 IPM in Production Ops 400 IPM in Toolroom Ops, 1,000 IPM in Production Ops
Coolant capacity 56 gal 56 gal 56 gal
Coolant pump and wash power 750 Watt 750 Watt 750 Watt
Air pressure 90 PSI 2.5 CFM, or 18 at 90 PSI SCFM 90 PSI 2.5 CFM, or 18 at 90 PSI SCFM 90 PSI 2.5 CFM, or 18 at 90 PSI SCFM
Air quality Air dried/water separator upstream of VMC Air dried/water separator upstream of VMC Air dried/water separator upstream of VMC
Lubrication pump capacity 2 liter 2 liter 2 liter
Specifications subject to change. *** Height changes slightly based on how machine is leveled on leveling screws. **** Can vary slightly due to home switch location and soft limit settings.
TRAK VMC Models
TRAK VMC5 Specifications:
  • Table Size: 27.56″ x 15.75″
  • Travel (x, y, z): 20″ x 16″ x 20″
  • Footprint: 84″ x 129″
  • Horsepower: 15/10
TRAK VMC7 Specifications:
  • Table Size: 35.43″ x 19.69″
  • Travels (x, y, z): 30″ x 20″ x 20″
  • Footprint: 97″ x 134″
  • Horsepower: 15/10
TRAK VMC10 Specifications:
  • Table Size: 44.09″ x 19.68″
  • Travels (x, y, z): 40.75″ x 20″ x 20″
  • Footprint: 111″ x 134″
  • Horsepower: 15/10
