ProtoTRAK RX CNC Software (RMX, RLX)
Versión: 3.1.0
Machining Centers
TRAK VMC2
TRAK TMC5
TRAK TMC7
TRAK TMC10
TRAK TMC12
TRAK TMC14
Turning Centers
TRAK TC2
TRAK DPM RX2
TRAK DPM RX3
TRAK DPM RX5
TRAK DPM RX7
TRAK TRL 1630RX
TRAK TRL 1630HS-RX
TRAK TRL 1845RX
TRAK TRL 2470RX
TRAK TRL 3060RX
TRAK TRL 30120RX
ProtoTRAK RMX2 Retrofit
ProtoTRAK Upgrades
MX Series to RMX Upgrade
M Series to RMX Upgrade
AGE Series to RMX Upgrade
EDGE Series to RMX Upgrade
EMX to RMX Upgrade
SM to RMX Upgrade
SMX to RMX Upgrade
KMX to RMX Upgrade
New products added:
  • TC2 RLX, high speed and low speed (id’s 177 & 178)
  • 3 axis RMX Kneemill with programmable Spindle (id 184)
New features:
  • Added actual runtime vs estimated runtime (EPA content added)
  • Turning the 4th axis ON / OFF no longer requires a reboot
  • ** front panel button now toggles between INCH / mm
  • Added CutOff Release option to lathe Cutoff event (EPA content added)
  • Added software support for Z EHW option on bedmills (release of hardware TBD later)
  • Merged previous 3.0.3 software for Brush Motor machines
  • TRAKing and EHW options can now be purchased & activated separately
Instructions for updating RMX & RLX Pendants
  1. Disable your anti-virus software before downloading. (Some anti-virus software may silently omit necessary files, and cause your machine to have unexpected symptoms.)
  2. Be sure to delete any previous PT10-SETUP folder from your USB flash drive first.
  3. Download the RX_x.x.x.zip file to your computer.
  4. Open the newly downloaded zip file to reveal the PT10-Setup folder.
  5. Unzip/extract the folder (or drag and drop it) from the zip screen to your USB drive.
  6. Navigate to your USB flash drive, and open the PT10-SETUP folder.
  7. Double click on ValidateFiles.exe
    This will run a quick CRC check to ensure that the download is complete and not corrupt. You should get a confirmation that looks like this:
    CRC Check Confirmation - ProtoTRAK RX CNC Software
    In the event that any of them failed, please retry the steps, making sure to disable your antivirus and deleting any previous instance of PT10-SETUP folder from your USB before proceeding.
  8. Take your USB flash drive and plug it into your ProtoTRAK RMX / RLX control.
  9. Go to SETUP, SERV CODES and then enter code 316, and press ABS SET.
  10. Highlight the drive letter corresponding to your USB flash drive, and then press YES twice to initiate the software update.
