TRAK DPM SX2P Bed Mill
Note: This machine has been replaced by the DPM RX2 Bed Mill featuring the ProtoTRAK RMX CNC.
DPM SX2P Bed Mill with the ProtoTRAK SMX CNC
DPM SX2P Features
  • ProtoTRAK SMX CNC integrated into the machine at the factory
  • 3 hp continuous spindle motor
  • R8 spindle taper
  • Manual quill with integrated quill and ram encoders
  • Real handwheels so you can work manually
ProtoTRAK SMX CNC
ProtoTRAK SMX
High-end CNC for one-off and small lot work
  • Available on TRAK® mills and as a knee mill retrofit for over 40 makes and models
  • Powerful but easy to learn and use
  • 2 or 3-axis CNC, 3-axis DRO
  • Run in manual or CNC mode
  • Runs ProtoTRAK conversational language, G-code, CAM, 2 and 3-D CAD converter software, and Verify Simulation software*
*Some features are optional
SX Bed Mill Specifications
  SX2P SX3P SX5P FHM7
Table size 49″ x 9″ 50″ x 10″ 50″ x 12″ 76″ x 14″
T-slots (number x width) 3 x 16mm 3 x 16mm 3 x 16mm 4 x 16mm
Travel (X, Y, Z axis) 32″ x 16″ x 23.5″ 31″ x 17″ x 23.5″ 40″ x 20″ x 23.5″ 60″ x 23″ x 20.5″
Quill diameter 3.375″ 3.9375″ 3.9375″ 5.06″
Maximum quill travel 5″ 5″ 5″ n/a
Spindle taper R8 NMTB 40 NMTB 40 NMTB 40
Spindle speed range RPM 40 - 600, 300 - 5000 40 - 600, 300 - 5000 40 - 600, 300 - 5000 200 - 5000
Spindle center to column face 18″ 19″ 20″ 23.75″
Spindle motor HP 3 HP 5 HP 5 HP 7.5 HP
Power requirements - control 110V, 1P, 12 Amp 110V, 1P, 12 Amp 110V, 1P, 12 Amp 110V, 1P, 12 Amp
Power requirements - machine 220V, 3P, 11 Amp 220V, 3P, 17.5 Amp 220V, 3P, 17.5 Amp 220V, 3P, 37.5 Amp
Maximum weight of workpiece 1320 lbs. 1320 lbs. 1760 lbs. 2200 lbs.
Height of table from bottom of bed 33″ 38″ 41″ 38.25″
Max spindle nose to table 27″ 23.5″ 23.5″ 24″
Min height 90″ 85″ 87″ 91.75″
Max height 98″ 95″ 98″ 101″
Width of machine including table 70″ 73″ 94″ 110.5″
Length with electrical door closed 64″ 66″ 71″ 93.75″
Length with electrical door open 72″ 76″ 81″ 119.5″
Overall width incl full table traverse 104″ 108″ 136″ 171.65″
Footprint of machine 23″ x 40″ 24″ x 44″ 24″ x 48.4″ 42.5″ x 63″
Weight net / shipping lbs. 3200 / 3500 4100 / 4400 4400 / 4600 7650 / 7975
Rapid traverse X, Y, Z 150 IPM 150 IPM 150 IPM 250 IPM
Handwheel type Mechanical, electronic optional Mechanical, electronic optional Electronic Electronic
Way Surface Type Dovetail X, Y, Z Dovetail X, square Y and Z Dovetail X, square Y and Z Dovetail X, square Y and Z
Drilling max capacity in mild steel 1″ dia. 1″ dia. 1″ dia. 1″ dia.
Milling max capacity in mild steel 3 inch³/min 5 inch³/min 5 inch³/min 7 inch³/min
Tapping max capacity in mild steel .75″ 1″ 1″ 0.625″
Hardware Options
TRAKing Electronic Handwheels
TRAKing/Electronic Handwheels
The feel of manual control of real handwheels, but our electronic handwheels bring the power of the CNC to your fingertips through features such as TRAKing and DO ONE. Standard for TRAK DPM SX5P and TRAK FHM7.
Model DX6 6’ Kurt Vise
Vise
Model DX6 6’ Kurt vise and mounting hardware.
Torque-Rite Power Draw Bar
The non-fogging coolant sprayer directs a fine stream of coolant to the tool and workpiece.
Halogen Work Lamp
LED Work Lamp
Convenient light with bright, long-lasting LED bulb.
Chip Tray/Splash Shield
Chip Tray/ Splash Shield
Combines a chip pan mounted to the bed and splash shields mounted to the right and left of the column. Available factory installed only – not available after shipment.
A glass scale mounted on the table and saddle.
Tableguard
Tableguard
Provides an enclosed work-space mounted on the table. The sliding door is switched to prevent operation of CNC Run with door open.
Switches and brackets to set maximum travel limits. Tripping the switch will cause servo motors to shut down.
Especificaciones de la RX2:
  • Tamaño de la Mesa: 1,244.60 mm (49″) x 228.6 mm (9″)
  • Desplazamiento (X & Y): 806.45 mm (31.75″) x 406.40 mm (16″)
  • Motor del Husillo: 3 HP
Especificaciones de la RX3
  • Tamaño de la Mesa: 1,270 mm (50″) x 254 mm (10″)
  • Desplazamiento (X & Y): 800.10 mm (31.5″) x 431.80 mm (17″)
  • Motor del Husillo: 5 HP
Especificaciones de la RX5:
  • Tamaño de la Mesa: 1,270 mm (50″) x 304.80 mm (12″)
  • Desplazamiento (X & Y): 1,016 mm (40″)x 508 mm (20″)
Especificaciones de la RX7:
  • Tamaño de la Mesa: 1,930.40 mm (76″) x 355.60 mm (14″)
  • Desplazamiento (X & Y): 1,524 mm (60″) x 584.20 mm (23″)
  • Motor del Husillo: 7.5 HP
