{intro_text_before_h1}
TRAK SX Series Toolroom Lathes
{sub_text_below_h1}
Note: These machines have been replaced by TRAK RX Series Lathes featuring the ProtoTRAK RLX CNC.
TRAK TRL 1845SX Toolroom Lathe
The ProtoTRAK® CNC is always easy to use:
  • Manual Turning when you need it
  • CNC with manual tool changes
  • Light production CNC with programmed tool changes
The ProtoTRAK SLX CNC
The CNC that can work like a DRO
Manual turning has never been more productive. The DRO features of the ProtoTRAK SLX CNC will make every turning job easier.
Tool setting is precise and easy
Tool data is even useful in manual operation.
Thread without sweating
A few inputs into the ProtoTRAK SLX or ELX CNC and the control will make easy work out of manual threading. You will not miss the old way.
Precision Ground Ballscrews
For accurate, precise positioning.
Real Handwheels
So you can move the machine manually when that's the best way to get something done.
Cycle Programming
Automatically remove stock with a few inputs.
Generous X axis travel
To accommodate a variety of tool setups.
TRAKing® Our favorite option!
You control CNC program run by cranking one of the handwheels. You have to see it to appreciate what it will do for your productivity.
1440EX Contiene:
  • Diám. sobre Bancada 14″, 40″ entre Centros
  • Diámetro a través del Husillo 1.56″
  • CNC ProtoTRAK ELX
1630RX Contiene:
  • Diám. sobre Bancada 16″, 30″ entre Centros
  • Diámetro a través del Husillo 2.12″
  • CNC ProtoTRAK RLX
1630HS-RX Contiene:
  • Diámetro a través del Husillo 1.57″
  • CNC ProtoTRAK RLX
1845RX Contiene:
  • Diám. sobre Bancada 18″ swing, 45″ entre Centros
  • Diámetro a través del Husillo 2.36″
  • Rangos de velocidades bajos y altos
  • CNC ProtoTRAK RLX
2470RX Contiene:
  • Diám. sobre Bancada 24″, 70″ entre Centros
  • Diámetro a través del Husillo 4.09″
  • CNC ProtoTRAK RLX
30120RX Contiene:
  • Diám. sobre Bancada 43.5″ balancearse sobre la brecha 15.5″
  • Diámetro a través del Husillo 6.30″
  • CNC ProtoTRAK RLX
