3ntr 3D Printer Specifications
Dimensional Data
A2 A4
Printer Dimensions 820 x 937 x 1140 mm
32.3 x 36.9 x 44.9″
635 x 560 x 710 mm
24.8 x 22 x 28″
Printer Weight 110 kg (242 lbs.) 43 kg (94 lbs.)
Shipping Dimensions 890 x 1067 x 1320 mm
35 x 42 x 52″
622 x 673 x 973 mm
24.5 x 26.5 x 38.3″
Shipping Weight 226 kg (498 lbs.) 69 kg (152 lbs.)
Electro / Mechanical Data
A2 A4
Ambient Operating Temperature 16-32° C (61-90° F)
Storage Operating Temperature 5-40° C (41-104° F)
AC Input 220/230 VAC - 15A 110/120 VAC - 10A
220/230 VAC - 10A
Connectivity USB, Micro SD, LAN
Steel Cabinet/Frame Construction 2mm (.08″) Powder Coated
Clear Panels Polycarbonate
Heated Print Bed Anticorodal aluminum 6082
Printing Specifications
A2 A4
Printer Technology FFF (Fused Filament Fabrication)
Number of Extruders 3
Build Volume — W x D x H1 600 x 300 x 500mm
23.6 x 11.8 x 19.6″
295 x 156 x 200mm
11.6 x 6.1 x 7.8″
Filament Diameter 2.85 mm +/- 0.1 mm
Standard Nozzle Diameter2 0.4 mm (.01575″)
Maximum Extruder Temperature3 430° C (806° F)
Maximum Heated Bed Temperature4 130° C (266° F) 110° C (230° F) 110V
130° C (266° F) 220V
Maximum Heated Chamber Temperature5 90° C (194° F) 80° C (176° F) 110V
90° C (194° F) 220V
Minimum Layer Thickness 40 Microns (0.00157″)
Positioning Precision – Z 40 Microns (0.00157″)
1 Build volume increases based on nozzle configuration 2 Available nozzles: .3 mm, .4 mm, .6 mm, .8 mm & .4 mm hardened anti-abrasion 3 Standard / Optional maximum nozzle temperature: 430° C on 2 of 3 nozzles 4 Measured at the heater on the aluminum print base 5 In conjunction with heated bed at maximum temperature
All specifications are subject to change due to ongoing research and product development.
A2v4 3D Printer by 3ntr
A2 3D Printer from 3ntr
A4v4 3D Printer by 3ntr
A4 3D Printer from 3ntr
Contact us today for a quote or to schedule a 3D printer demo. Toll free: 800‑421‑6875
