The feel of manual control of real handwheels, but our electronic handwheels bring the power of the CNC to your fingertips through features such as TRAKing and DO ONE. Standard for TRAK DPM SX5P and TRAK FHM7.
Vise
Model DX6 6’ Kurt vise and mounting hardware.
The non-fogging coolant sprayer directs a fine stream of coolant to the tool and workpiece.
LED Work Lamp
Convenient light with bright, long-lasting LED bulb.
Chip Tray/ Splash Shield
Combines a chip pan mounted to the bed and splash shields mounted to the right and left of the column. Available factory installed only – not available after shipment.
A glass scale mounted on the table and saddle.
Tableguard
Provides an enclosed work-space mounted on the table. The sliding door is switched to prevent operation of CNC Run with door open.
Switches and brackets to set maximum travel limits. Tripping the switch will cause servo motors to shut down.
