TRL 30120RX Toolroom Lathe
Our largest lathe with outstanding travels & capacities
TRL 30120RX Toolroom Lathe featuring the ProtoTRAK RLX CNC
TRAK TRL 30120RX Lathe Overview
Our newest and largest lathe has the power and capacity to handle big jobs — and it comes equipped with the easy-to-use ProtoTRAK RLX CNC. The 30120 features a 30 HP spindle motor, 33″ swing, 118″ between centers and a 43.5″ swing over a 15.5″ gap.
TRL 30120RX Features
  • Gap bed lathe with 43.5″ swing over 15.5″ gap
  • 118″ between centers with 121″ maximum cutting length
  • Large 6.30″ spindle through hole
  • 20.5″ of cross slide travel
  • 30 HP continuous spindle motor
  • Interface for rear chuck
  • High (aluminum) and low (steel) speed range settings
  • Tailstock - standard equipment
  • Coolant pump - standard equipment
  • 3 work lights - standard equipment
Standard on RX Series Lathes
  • ProtoTRAK RLX CNC integrated into the machine at the factory
  • Constant Surface Speed (CSS) Programming
  • Inch Per Revolution (IPR) Programming
The ProtoTRAK® RLX CNC
The ProtoTRAK RLX CNC for the 30120RX Lathe
Make every job easier and more productive.
Specifications All Machines
  1440EX 1630RX 1630HS-RX 1845RX 2470RX 3075RX 30120RX
ProtoTRAK CNC Model
ELX RLX RLX RLX RLX RLX RLX
Height of Centers 7″ 8″ 8″ 9″ 12″ 15″ 16.5″
Distance between centers 40″ 30″ 30″ 45″ 70″ 74.80″ 118″
Swing over bed 14″ 16″ 16″ 18.1″ 24″ 30″ 33″
Swing Over Saddle Wings 14″ 16″ 16″ 17″ 24″ 28″ 33″
Swing Over Cross Slide 7″ 8.6″ 8.6″ 9.13″ 14.5″ 19″ 21.2″
Cross Slide Travel 8″ 8.5″ 8.5″ 10.6″ 12.5″ 16.1″ 20.5″
Tool Section Max 3/4″ 3/4″ 3/4″ 1″ 1″ 1.5″ 1.5″
Coolant Reservoir Capacity 3 gal 8 gal 8 gal 13 gal 15 gal 47 gal 48 gal
Oil Pump - Way Lubrication - 2 l 2 l 2 l 2 l 2.3 l 2 l
Head Stock Lubrication - 1.5 gal 1.5 gal 1.85 gal 5.3 gal
6.3 gal w/oil cooler option
6 gal 8.5 gal
Rapid Speeds 100 IPM on Z Axis
100 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
Bed
Width Of Bed 8.1″ 12.6″ 12.6″ 13.4″ 14.57″ 18″ 19.69″
Height Of Bed 10.6″ 12.6″ 12.6″ 12.4″ 15″ 15.75″ 18.7″
Spindle Nose D1-4 D1-6 A2-4 D1-6 D1-8 A2-11 A2-11
Spindle Through Hole 1.56″ 2.12″ 1.57″ 2.36″ 4.09″ 6.69″ 6.30″
Spindle Taper MT#5 MT#6 MT#5 MT#6 MT#8 Non MT taper MT#8
Taper In Reduction Sleeve 3 n/a n/a MT#4 MT#5 MT#6 MT#5
Spindle Dia At Front Bearing 2.36″ 3.15″ 2.56″ 3.35″ 5.51″ 8.66″ 7.87″
Number Of Bearings 2 2 5 2 2 2 2
Number of Speeds or Ranges 12 1 1 2 2 2 2
Spindle Speed Range RPM 60-2,400 150-2,500 150-4,000 80-850, 250-2,500 40-670, 100-1,800 20-415, 40-1,300 30-300, 100-1,000
Spindle ID Thread (end of spindle) n/a M56 x 2MM Pitch M56 x 2MM Pitch n/a n/a M185 x 3.0 n/a
Quill Travel 5″ 5.75″ 5.75″ 6″ 8.5″ 8″ 8″
Quill Diameter 1.575″ 2.36″ 2.36″ 2.56″ 3.5″ 4.875″ 4.13″
Quill Taper Hole MT#3 MT#4 MT#4 MT#4 MT#5 MT#6 MT#6
Spindle Motor
Horsepower 5 HP 7.5 HP 7.5 HP 10 HP 15 HP 30 HP 30 HP
Power Requirements - Machine
Voltage Control: 110V
Machine: 200V - 240V
200V to 240V 200V to 240V 200V to 240V 200V to 240V 480V +/- 10%
(432V to 528V)
480V +/- 10%
(432V to 528V)
Amps Full Load Current Control: 8A
Machine: 15A
44A 44A 54A 73A 71.6A 62A
Phase/Hz Control: 1/60
Machine: 3/60
3/60 3/60 3/60 3/60 3/60 3/60
Net (L x W x H), lbs. 73″ x 44″ x 57″
1,800 lbs
82″ x 45″ x 72″
2,750 lbs
82″ x 45″ x 72″
2,750 lbs
88″ x 55″ x 70″
3,285 lbs
129″ x 84″ x 79″
6,500 lbs
170″ x 82″ x 77″
15,430 lbs
212.6″ x 86.61″ x 79.53″
18,920 lbs
Shipping (L x W x H), lbs. 78″ x 49″ x 67″
2,200 lbs
87″ x 45″ x 70″
3,420 lbs
87″ x 45″ x 70″
3,420 lbs
91″ x 52″ x 79″
3,800 lbs
134″ x 65″ x 79″
6,900 lbs
225″ x 89″ x 88″
16,530 lbs
222.44″ x 90.55″ x 110.23″
19,270 lbs
Coolant Pump Motor HP* 1/8 HP 1/8 HP 1/8 HP 1/8 HP 1/8 HP 3/4 HP 1/4 HP
Spindle Motor Brake Magnetic Dynamic Dynamic Dynamic Dynamic Dynamic Dynamic
Way Surface Hardness 400-450 HB 400-450 HB 400-450 HB 480-560 HB 480-560 HB 480-560 HB 480-560 HB
Head Stock Lubrication Splash Lube Oil Bath Grease Oil Bath Oil Bath Oil Bath Oil Bath
Tooling Kit 3/4″ 3/4″ 3/4″ 3/4″ or 1″ 1″ 1-1/4″ 1-1/4″
Chuck 6″, D1-4 8″, D1-6 6″, A2-4 8″, D1-6 12″, D1-8 20″, A2-11 20″, A2-11
5C Collet Closer D1-4 D1-6 A2-4 D1-6 n/a n/a n/a
Turret Option n/a 3/4″, 8 Position
1″, 8 Position 1″, 8 Position
* Coolant pumps are optional equipment.
TRAKing<sup>®</sup> for RX Lathes
TRAKing® for RX Lathes
TRAKing of programs during program run, GO TO Dimension in DRO Mode.
VIDEO: TRAKing® Option Overview
Buck Chuck
Buck Chuck
1630RX 8″ D1-6 2.36″
1630HS-RX 6″ A2-4 1.77″
1845RX 8″ D1-6 2.36″
2470RX 12″ D1-8 4.16″
3075RX 20″ A2-11 7.48″
30120RX 20″ A2-11 7.48″
Rear Chuck & Adapter - 30120RX
Optional 16″ rear chuck and chuck adapter for the 30120RX. Both front and rear chucks are balanced at the factory when purchased with the machine. Chucks purchased separately may need to be balanced.
For the TRL 30120RX only.
Option Description
Rear chuck & adapter 16″ chuck
Adapter - rear chuck Adds A2-11 spindle nose
8 Station Turret for Long Travel Lathes
The 8-station turret for TRAK Long Travel Lathes uses 1″ tooling and supplies coolant at each tool. Clamping is accomplished through hydraulics.
3075RX 1″
30120RX 1″
VIDEO: 8-Station Turret for TRAK® Long Travel Lathes
Dorian® brand tooling kits make tool changes quick and easy. Repeatable to .001″. The 1-1/4″ tooling kit for the 3075RX and 30120RX includes:
  • (1 ) Quick change tool post
  • (4) Square tool holders for turning, facing and boring
  • (1) Boring tool holder (1.50″)
  • (1) Morse taper holder (MT5)
  • (1) T-slot nut
Chip Conveyor
Chip Conveyor
TRAK offers a hinged belt-style chip conveyor for the TRL 30120RX. The conveyor receives power directly from the lathe and is controlled by the operator with a switch on the pendant.
1630RX 14″
1630HS-RX 14″
1845RX 14″
2470RX 20″
3075RX 30″
30120RX 30″
Lathe Diameter Type
1440EX 1.97″ Solid Brass Nib
1630RX 5″ Solid Brass Nib
1630HS-RX 5″ Solid Brass Nib
1845RX 3.94″ Solid Brass Nib
2470RX 6.5″ Solid Brass Nib
3075RX 5.5″ Solid Brass Nib
30120RX 0.79 - 7.87″ Solid Brass Nib
Steady Rest - 30120RX
Lathe Diameter Type
30120RX 1.18 to 11.02″
10.43 to 21.65″
Roller
The 30120RX comes with 2 sets of fingers.
Available for purchase at our service parts website: Remote Stop/Go Switch
TRAK<sup>®</sup> USB Memory
TRAK® USB Memory
VIDEO: TRAK® USB Memory Option Overview
CAM File Out Converter
Write, save and then run programs with RX Canned Cycle Events on Legacy ProtoTRAK controls in either .CAM Events or .GCD format.
Auxiliary Output
Auxiliary Output
Programmable output signal.
Offline Programming
Offline Programming
  • ProtoTRAK RX user interface for Windows® PC
VIDEO: Installing ProtoTRAK Offline Software
DXF Converter
DXF Converter
  • Part alignment
  • Feature analysis (circle/arc radius and position)
  • Simple CAD construction/editing tools
  • DXF-output capability
Not available for the ProtoTRAK ELX.
Advanced Features
Advanced Features
  • Thread Repair
  • Gang Tool setup
  • Custom Thread event
  • Tap event
  • Search Edit
The TRAK MTConnect option enables customers to add MTConnect functionality quickly and easily to their machines, so that machine data can be collected using the standard MTConnect protocol.
  • Machine networking through ethernet connection or USB Wi-Fi adapter
  • Collect machine data throughout shop
  • Monitor machine status, receive notifications and analyze data throughout your machines’ history
3rd party software not included.
VIDEO: MTConnect® Option Overview
TRAK RX Series Toolroom Lathes Overview featuring the TRL 1845RX
8-Station Turret for TRAK Long Travel Lathes
Managing Files with the ProtoTRAK RX CNC
Other TRAK CNC Lathe Models:
1440EX Features:
  • 14″ swing, 40″ btw. centers
  • Spindle through hole of 1.56″
  • ProtoTRAK ELX CNC
1630RX Features:
  • 16″ swing, 30″ btw. centers
  • Spindle through hole of 2.12″
  • ProtoTRAK RLX CNC
1630HS-RX Features:
  • Spindle through hole of 1.57″
  • ProtoTRAK RLX CNC
1845RX Features:
  • 18″ swing, 45″ btw. centers
  • Spindle through hole of 2.36″
  • High & low speed ranges
  • ProtoTRAK RLX CNC
2470RX Features:
  • 24″ swing, 70″ btw. centers
  • Spindle through hole of 4.09″
  • ProtoTRAK RLX CNC
