{intro_text_before_h1}
TRL 2470SX Toolroom Lathe
{sub_text_below_h1}
Note: This machine has been replaced by the TRL 2470RX Lathe featuring the ProtoTRAK RLX CNC.
TRL 2470SX Toolroom Lathe with the ProtoTRAK SLX CNC
TRL 2470SX Features
  • 24″ swing, 70″ between centers
  • Generous 4.09″ spindle through hole
  • 15 HP continuous spindle motor
  • Geared head for good performance at low speeds
  • Tapered roller bearings
  • High (aluminum) and low (steel) speed range settings
Standard on all SX Series Lathes
  • ProtoTRAK SLX CNC integrated into the machine at the factory
  • Optional Constant Surface Speed (CSS) Programming
  • Optional Inch Per Revolution (IPR) Programming
  • Optional turret and indexer for automatic tool changes
  1440EX 1630SX 1630HSSX 1845SX 2470SX
Height of Centers 7″ 8″ 8″ 9″ 12″
Distance between centers 40″ 30″ 30″ 45″ 70″
Swing over bed 14″ 16″ 16″ 18.1″ 24″
Swing Over Saddle Wings 14″ 16″ 16″ 17″ 24″
Swing Over Cross Slide 7″ 8.6″ 8.6″ 9.13″ 14.5″
Cross Slide Travel 8″ 8.5″ 8.5″ 10.6″ 12.5″
Tool Section Max 3/4″ 3/4″ 3/4″ 1″ 1″
Coolant Reservoir Capacity 3 gal. 9.3 gal. 9.3 gal. 12 gal. 15 gal.
Head Stock Lubrication Splash Lube Oil Bath Grease Oil Bath Oil Bath
Rapid Speeds 100 ipm on Z Axis
100 ipm on X Axis
150 ipm on Z Axis
100 ipm on X Axis
250 ipm on Z Axis
100 ipm on X Axis
250 ipm on Z Axis
100 ipm on X Axis
250 ipm on Z Axis
100 ipm on X Axis
Bed
Width Of Bed 8.1″ 12.6″ 12.6″ 13.4″ 14.57″
Height Of Bed 10.6″ 12.6″ 12.6″ 12.4″ 15″
Spindle Nose D1-4 D1-6 A2-4 D1-6 D1-8
Spindle Through Hole 1.56″ 2.12″ 1.57″ 2.36″ 4.09″
Spindle Taper MT#5 MT#6 MT#5 MT#6 MT#8
Taper In Reduction Sleeve 3 n/a n/a MT#4 MT#5
Spindle Dia At Front Bearing 2.36″ 3.15″ 2.56″ 3.35″ 5.51″
Number Of Bearings 2 2 5 2 2
Number of Speeds or Ranges 12 1 1 2 2
Spindle Speed Range RPM 60-2400 150-2500 150-4000 80-850, 250-2500 40-670, 100-1800
Standard Optional Optional Standard Standard
Quill Travel 5″ 6.3″ 6.3″ 6″ 8.5″
Quill Diameter 1.575″ 2.36″ 2.36″ 2.56″ 3.5″
Quill Taper Hole MT#3 MT#4 MT#4 MT#4 MT#5
Spindle Motor
Horsepower 5 HP 7.5 HP 7.5 HP 10 HP 15 HP
Power Requirements
Power Requirements - Control 110V / 1P / 8A 110V / 1P / 12A 110V / 1P / 12A 110V / 1P / 12A 110V / 1P / 12A
Power Requirements - Machine 220V / 3P / 60Hz 220V / 3P / 60Hz 220V / 3P / 60Hz 220V / 3P / 60Hz 220V / 3P / 60Hz
Amps Full Load Current 15 25 25 33 42
Net (L x W x H), lbs. 73″ x 44″ x 57″
1800 lbs.
82″ x 46″ x 72″
2875 lbs.
82″ x 46″ x 72″
2875 lbs.
94″ x 52″ x 73″
3285 lbs.
129″ x 60″ x 77″
6500 lbs.
Shipping (L x W x H), lbs. 78″ x 49″ x 67″
2200 lbs.
85″ x 46″ x 67″
3420 lbs.
85″ x 46″ x 67″
3420 lbs.
91″ x 52″ x 84″
3800 lbs.
134″ x 64″ x 77″
6900 lbs.
Coolant Pump Motor HP* 1/8 HP 1/8 HP 1/8 HP 1/8 HP 1/8 HP
Spindle Motor Brake Magnetic Dynamic Braking Dynamic Braking Dynamic Braking Dynamic Braking
Way Surface Hardness 400-450 HB 400-450 HB 480-560 HB 480-560 HB 400-560 HB
Tooling Kit 3/4″ 3/4″ 3/4″ 3/4″ or 1″ 1″
Chuck 6″ D1-4 8″, D1-6 6″, A2-4 8″, D1-6 12″, D1-8
5C Collet Closer D1-4 D1-6 A2-4 D1-6 n/a
Turret Option n/a 3/4″, 8 Position
TRAK® CNC Turrets — All New Designs
TRAK 8-Station CNC Turret
TRAK® 8-Station CNC Turret
1630SX 3/4″
1630HSSX 3/4″
1845SX 3/4″ or 1″
2470SX 1″
TRAK® 4-Station CNC Turret
1630SX 3/4″
1630HSSX 3/4″
1845SX 3/4″ or 1″
2470SX 1″
Buck Chuck
1440EX 6″ D1-4 1.57″
1630SX 8″ D1-6 2.36″
1630HSSX 6″ A2-4 1.77″
1845SX 8″ D1-6 2.36″
2470SX 12″ D1-8 4.16″
Standard equipment on 1440EX, 1845SX and 2470SX lathes. Optional on 1630SX and 1630HSSX lathes.
Dorian® brand tooling kits make tool changes quick and easy. Repeatable to .001″. The kits include:
  • 1 quick change tool post
  • 4 each 3/4″ or 1″ square tool holders for turning, facing and boring
  • 1 boring tool holder (for the 3/4″ kit: 1″ holder; for the 1″ kit: 1.25″ holder)
1630SX 3/4″
1630HSSX 3/4″
1845SX 3/4″ or 1″
2470SX 1″
1630SX 14″
1630HSSX 14″
1845SX 14″
2470SX 20″
Follow Rest (Solid brass nib type)
1440EX 1.97″
1630SX 5″
1630HSSX 5″
1845SX 3.94″
2470SX 6.5″
Steady Rest
Steady Rest (Roller type)
1440EX .20 to 2.36″
1630SX .500 to 5.75″
1630HSSX .500 to 5.75″
1845SX 0.4 to 7.87″
2470SX 1.5 to 8″
Remote Stop-Go Switch
Other Options Include:
  • 5C Collet Closer - with extended taper mount nosepiece (Not available for 2470SX)
  • Coolant Pump - May be configured to operate as commanded by the Accessory Key on the ProtoTRAK SLX front panel. 1440EX coolant pump turned on and off by switch on apron.
  • Work Lamp - mounts to the underside of the chip enclosure
1440EX Features:
  • 14″ swing, 40″ btw. centers
  • Spindle through hole of 1.56″
  • ProtoTRAK ELX CNC
1630RX Features:
  • 16″ swing, 30″ btw. centers
  • Spindle through hole of 2.12″
  • ProtoTRAK RLX CNC
1630HS-RX Features:
  • Spindle through hole of 1.57″
  • ProtoTRAK RLX CNC
1845RX Features:
  • 18″ swing, 45″ btw. centers
  • Spindle through hole of 2.36″
  • High & low speed ranges
  • ProtoTRAK RLX CNC
2470RX Features:
  • 24″ swing, 70″ btw. centers
  • Spindle through hole of 4.09″
  • ProtoTRAK RLX CNC
30120RX Features:
  • 43.5″ swing over 15.5″ gap
  • Spindle through hole of 6.30″
  • ProtoTRAK RLX CNC
